MC Machinery will be showcasing the new Mitsubishi artificial intelligence-enabled sinker EDM as well as other EDM and milling machines at Eastec in booth 1420, where Mitsubishi EDM experts will be available to answer questions and provide live demos.
Eastec 2023 is scheduled for May 16-18 at the Eastern States Exposition in West Springfield, Mass.
Mitsubishi EDM machines at Eastec will include the Mitsubishi SG12 sinker EDM, the Mitsubishi MV2400 wire EDM and the Ingersoll Eagle V550 five-axis milling center.
Mitsubishi Sinker EDM
The SG12 sinker EDM’s AI and IoT technologies combine to provide insight into and control over its productivity, efficiency, uptime, maintenance and more.
The SG12 sinker comes with MC Machinery’s Remote360™ cloud-based machine monitoring system, which provides real-time expert remote diagnostics along with the seamless measurement of and access to valuable data that can provide the insight necessary to improve productivity, efficiency and profitability.
This combination of AI and remote monitoring can improve machine productivity by 30 percent and cut machining time in half while reducing waste and electrode wear.
Additionally, both new and experienced operators benefit from the Mitsubishi M800 CNC control with its 19-inch ergonomic touchscreen.
Mitsubishi Wire EDM
The MV2400-R Mitsubishi wire EDM is the perfect solution for applications requiring ± .0001 tolerance, also featuring a larger tank capacity and low operational costs. The innovative MV-R series features improvements in machine construction, auto-threading, internal machine communication and power supply technology. It also highlights Mitsubishi’s dedication to high precision, with innovations including the highly reliable non-contact cylindrical drive system on the X, Y, U, and V axis drives.
Ingersoll Eagle V550 Machining Center
The Ingersoll Eagle V550 graphite machining center features high-speed, high-precision five-axis machining for small graphite electrodes and mold/die components. Graphite machining can be a shop floor bottleneck, particularly with simultaneous complicated projects. The Eagle V550 is known for building electrodes faster and more efficiently.
